darkthunder
Mar 2005
Walled Lake, MI
What the hades is that block thingy bolted to the trans xmember do? Can I take it off? Thanks.
Antonio.
darkthunder - 85 TC// 302/C4
2009 Subaru WRX//daily driver
I was wondering the same thing.... If I remember correct, when I changed my ujoints I was going to leave it off, but I dont think I could for some reason.....
martin0660
Jun 2002
Greensburg, PA
Its a counterweight designed to reduce NVH, remember these are luxury cars I ripped mine off, and the one on the rear end, and it seemed to REDUCE vibrations The bolts on that one are a PITA as I remeber it.
Bob Myers
I also took the weights off. I have one more to remove....Bob, do you know the easiest way to get the weight off the drive shaft? Torch?
bob
darkthunder
Mar 2005
Walled Lake, MI
Coolness, I'm taking mine off too. Thanks.
Antonio.
martin0660
Jun 2002
Greensburg, PA
I used a BFH A torch may be a little more diplomatic
Bob Myers
Sluggo
May 2004
Huntingtown, MD., USA
bob
Mine came off while driving, not recommended if you can avoid.
Doug
