trans crossmember
billm Offline
For an '88 TurboCoupe is the trans crossmember the same for an automatic and a manual?
In otherwords. can I use a crossmember from an automatic car to replace the one on my T-5 car?
Thanks.
Bill
TurboCoupe50 Offline
Nope, the A4LD uses a unique crossmember and mounting scheme... I believe you can use one from any 3.8 or 5.0 automatic Bird for the T5...
1988 Turbo Coupe331 AOD
1972 Comet GT
87TurboBobby Offline
If not I have one off my TC if you need it. It is heavy so the shipping might be high. I bought one from FMS for a Mustang because it was lighter and it works perfect with a polyurethane Trans mount.
90 Mustang GT Vert.
95 Mustang Vert
04 F150 Heritage
92 Chevy Silverado
Rod K Offline
If you need a 5 speed crossmember you can use one from a Mustang (like 87turbobobby said). The one from a 4 cylinder or 5.0 will work.
Rod Kiser, '88TC, 5 speed, 5 lug, Cobra 13" front brakes, Mark VII 11 1/4" rear disc brakes, PiMP'n, Bullit wheels, ATR 3" exhaust, Aluminum driveshaft, EDIS, 60 LB injectors, gutted upper & ported lower. NATO Member
