muskrat
Jan 2003
eaton rapids,mi,48827
will the clutch peddle assy. work in a 1988 tbird from a 1981 mustang? want to do a 5 speed swap and have the mustang for parts.
TC88 from Finland
Feb 2003
Tampere, Finland (Europe)
I did the 5-speed swap using 89 4-cyl Mustang parts and they fit straight into 88 TC. I believe that pedal assy in 81 Mustang is same than in newer ones, so it should fit. You can also use Mustang clutch cable if you don't have hydraulic clutch parts. There is a hole in firewall of TC where cable mounts straight without cutting. The hole is normally used for routing boost gauge hose thru firewall, so new one (much smaller)has to be made for it
Lauri Salokangas
Tampere, Finland
1988 T-bird TC 5-spd (ex- automatic), black with dark blue/ grey interior.
85k miles, K&N filter, adjustable boost, Ford Racing 9mm plug wires, Philips hi-fi system with CD-changer. ATC, moonroof, dual power seats, premium sound, keyless entry, autolamps/ dimmer, cornering lights, power antenna
Lauri Salokangas
Tampere, Finland
1988 TC 5-spd, black with raven int.
K&N, CAI, Gills, Walbro 255lph, Kirban AFPR, BOV, 3" Stinger exhaust. Rebuilt diff and trans, 3G alt, Energy Suspension bushings, KYBs
1984 Mustang SVO
