tps locatation
Noname
Guest
Does anyone have a picture of the back of the intake and throttle so I can figure out where the TPS mounts to with the two bolts. mine is just sitting there the bracket is on the plug but I can not see where it mounts on the engine. Thanks Mike
No picture, but maybe this will help... Remove the idle air bypass valve (IAB) from the back of the throttle body. It is the metal cylinder, about 1" in dia, and several inches long with a 2 wire elecrical plug on it. It is attached with 2 bolts, 5/16" head, I think. The TPS attaches right below the IAB. Removing the IAB makes installing the TPS easier. While you have the IAB off, blast the snot out of it with brake cleaner. If the gasket rips, just make a new one out of thin cardboard.
88 Turbo Coupe: Intake and exhaust mods, T3 turbo at 20 psi, forced air intercooler, water injection, bypass valve, Ranger roller cam, subframes, etc., etc.. // 86 Tbird 5.0: intake, exhaust, 100 HP nitrous, ignition, gears, suspension, etc., etc.... // 91 Escort: Bone stock winter car // 00 Windstar (wifes vehicle)
GT350R Offline
Cereal box to be specific [Image: smile.gif] Also so you know if the TPS is off you will have to adjust it when you put it on.There is an article on the main page of this board on how to do it.
GT350R
#1978 20th 2.3 Turbo T-top
#3608 20th 2.3 Turbo T-top
1985.5 TC
1987 TC 5 speed
1987 TC auto
1988 TC auto
1983 Mustang soon to be Turbo
My Garage
GT350R
84 Gt350 2.3T T-top
84 Turbo GT 418rwhp
My Garage
Noname
Guest
Thanks. I will take a look this weekend.
