TPS flat spots
RDOG Offline
I have a 92 supercoupe 60mm TB, and I need to check my TPS for flat spots. What am I looking for EXACTLY. A sudden zero/null reading?
Where does that flat spot typically occur? WOT?
86 XR7 5spd Offline
this troubleshoot is easier with an analog VOM,
because what you are looking for is:
a smooth and linear change in resistance across the TPS as you cycle it from closed -> open,
and back, open -> closed
(this presumes you have disconnected the TPS and are measuring 'resistance' across it's terminals;
if TPS is connected with power on,
you would expect a linear voltage change from near 0 to near 5 volts)
IIRC one pin (when referenced to ground 3rd pin) will go from high resistance -> 0,
while the second pin (ref'd to ground) will go from 0 -> high resistance...
check em both just to make sure Smile
David T
2.5" exhaust w/ cherry bomb
zip Offline
You will look for zero readings when checking the voltage between the output and ground on the TPS. Like said above its easier to see the dead spots with an analog meter. On my TPS the dead spot was early in the sweep, around 1.8V if I remember correctly.
Matt
RDOG Offline
[b] I have a 92 supercoupe 60mm TB, and I need to check my TPS for flat spots. What am I looking for EXACTLY. A sudden zero/null reading?
You will look for zero readings when checking the voltage between the output and ground on the TPS. Like said above its easier to see the dead spots with an analog meter. On my TPS the dead spot was early in the sweep, around 1.8V if I remember correctly. [/b]
When you found the problem, did you just replace the bad unit or was there a problem with the TB itself?
84TBirdTurbo42 Offline
its an issue with the sensor, not the tb.
Chris Perry
TurboCoupe50 Offline
It's best to use the voltage method...
With the meter positive connected to the TPS green wire and neg on ground check for a smooth voltage climb as you open the throttle... Any dip or drop out in voltage indicates a worn TPS...
NOTE when setting TPS voltage use the black wire on the sensor for ground, using the engine as ground may give a slightly different reading... A small voltage difference because of ground is not important when checking the TPS for dead spots...
1988 Turbo Coupe331 AOD
1972 Comet GT
zip Offline
It was a issue with my sensor. After replacement all was well.
Matt
RDOG Offline
Checked out my NONADUSTABLE TPS, and it was at .86. I read that its supposed to be at .90-.95 for best results. I set it to .92 because thats the best I could do by drilling the TPS holes slightly larger.
Is that OK?
if your within spec, which you are, then your good. As long as there's no dead spots in the TPS. you should be fine. There is often a little wiggle room with sensors, because not every sensor is going to be perfect.
Chris Perry
RDOG Offline
Out of curiosity, what happens if you are out of spec, for instance me being at only .86?
