Torque Settting: Exhaust Manifold Bolts
Gary S Offline
Did the search but it didn't return anything. I have it written down somewhere but can't find it. I need the torque setting for the exhaust manifold bolts on the 2.3.
Thanks,
Gary S.
1987 Turbocoupe
168,000 Miles
5 Speed
Black w/Raven Interior
http://www.turbotbird.com/showroom/data_...t_87tc.php
Not B Anymore Offline
Ford manual says to torque them in 2 steps. 5-7 lb-ft and then 16-23 lb-ft
Gary S Offline
Thanks Brian. Now for another stupid related question. If I am replacing the bolts one at a time, I assume that that I can just go ahead and use the final torque setting without the fear of warping anything?
1987 Turbocoupe
168,000 Miles
5 Speed
Gary,
I would get all the bolts started first before tightening them. Then do it in two stages like B said AND work from the center toward each end
BJL Offline
Moderator
/\ i agree, i always start from center back and forth out. i just torque then 15, then 35 ft lbs. but im also running a gasket there. and i re torque them every oil change.
Brian J Larkin
88TC 320k miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
gtrag94 Offline
do they ever loosen between oil changes?
1986 TC 5-spd (Red/Red cloth)
K&N Cone on VAM; front suspension by KYB, Moog, Energy Suspension.
