12-12-2020, 05:50 PM
(This post was last modified: 12-12-2020, 05:55 PM by BigJake.)
[img] ![[Image: P1060554.JPG?width=1920&height=1080&fit=bounds]](https://hosting.photobucket.com/images/jj208/Racingjake/P1060554.JPG?width=1920&height=1080&fit=bounds) [/img][img] ![[Image: P1060553.JPG?width=1920&height=1080&fit=bounds]](https://hosting.photobucket.com/images/jj208/Racingjake/P1060553.JPG?width=1920&height=1080&fit=bounds) [/img]
ARRMA Limitless vs Turbo Coupe
MPH Guess ?
V6TBird87
Apr 2002
Severn, Md, USA
I think the local speed record with a Limitless is 168mph.
I've never had a TC over 130.
2018 Mustang GT
1988 Turbo Coupe, 5-speed
aka Tbird232ci
Mikey97D
Jan 2018
CONNECTICUT
I think I am going to pick the one with 30 years more technology just don't hit a pebble.
MN88TurboCoupe
Apr 2011
Minneapolis, MN
Max speed in a TC for me has been 148. Speed limiter keeps shutting you down around 145 but if you ease of the throttle and press it down slowly you can get a little more speed.
Publicity, fame and accolades can make a theory popular. They can't make it true.
I was in fourth gear and just past 6200 rpm with one inch taller rear tires than OEM when I blew a freeze plug, was aiming for 6500 plus seeing if the engine could do it. Don't know how fast it was but thinking 130 range ?
Right now the Limitless will do 100 mph, so a bigger battery, motor, ESC and gearing is needed to reach 150 mph but weird things happen at that speed. So that's my after Xmas gift for me next, plus I need to get another GPS cause that broke when I hit the curb last weekend.
3500 lbs. Turbo Coupe - 1
12 lbs. Limitless - 0
If only Stinger could Pimp my Limitless LOL
hm looks car has high speed
03-30-2021, 04:13 PM
(This post was last modified: 03-30-2021, 04:14 PM by BigJake.)
This thing is crazy wild, was hauling the mail and hit a dip and the car flew up in the air and flipped end over end and landed back on all four wheels and kept going with no damage. Also gave it a hard left and WOT and was spinning like a top when it flipped upside down on it's roof and when it slowed down she flipped back up right and sped away. A kid watching couldn't believe what happen. LOL
PS. Got a bigger motor, ESC and now she's on 8S power looking for 150 mph
