I'm in the process of building my new engine.The #2 cylinder wall has a couple of decent scratches from the ring gap.Would a .030 over bore be advantageous power wise or would a good honing to remove the scratches be sufficient?If overbored would I be safer using oversized pistons or just oversized rings?
Shannon
ashleyroachclip
Sep 2001
Roseburg Oregon
the scratches will be the determining factor as to whether you over bore or just hone .First i would see if the scratches will hone out . If they don't then you will have to bore . The most that I would bore it would be 30 over , and then you will definately need to get 30 over pistons. I hope this helps
clowns to the left of me , jokers to the right
