tires
Noname
Guest
i know this has been talked about before i am going to need tires soon for my 87 t.c. with stock 16 inch snowflakes and i would like to go about 1 inch wider on the tires and maybe a little shorter but i want the speedo to be fairly close to normal what are some of you guys running as far as different sizes? and if you had any problems thanks for any info p.s. i hope that everyone that is going to carlise has a great time hopefully next year i can make it and have some fun talking to everyone thanks again mike
TurboCoupe50 Offline
I use a pair of 225/50/16 Mitchelin XGT sports to race on. They are about a inch shorter and wider than the 225/60/16s. I haven't noticed a problem, but a smaller tire will make the speedo readings a little faster than the car is actually traveling.
1988 Turbo Coupe331 AOD
1972 Comet GT
GaryS#2 Offline
I've got 225/50/16 BFG and they are nice size for the car.Takes off quik and makes the car feel peppier.I like the fact that my speedo is out a bit.Gives me some leeway for radar.lol
Grocery Getter/Rice Cooker.
Kev Offline
The 225s are the stock width on the 87/88 TCs. To go much wider would hurt you in the curves. The 50 height is shorter and creates a shorter sidewall (duh) so it makes the sidewall stronger and helps you in the twisties. The snowflake rim is only 7" wide and to go to a wider tire you really should think about a wider rim. I went from 225/60 in the back of my 88 to 245/50 Awesome off the line (still not enough, in fact) but here in northern Arkansas they suck for zipping around the mountains at high speeds. Makes the rear float out real bad. Try some performance 225/50/16 and lower the car an inch. That would look and feel really good. Just some food for thought...
Kev
88 TC 5spd
K&N in front of the radiator, no mufflers, no cat=straight pipes all the way out the duals, bypassed BCS
Car is all black, no red stripe, blackouts, and chrome duals, red leather interior
Mean Fast and Smooth
Kev
1988 TC 5spd
Kev Offline
I forgot to say, with the 50s in the back it makes my speedo about 5mph fast at 60mph.
Kev
Kev
88 TC 5spd
Kev
1988 TC 5spd
