tire size for stock rims
danadj Offline
Will a 245 fit on the stock rim?
-Derek
88TC Black 5spd conversion, 160k+, with front mounted air filter, Gillis Boost Valve at 15 psi until i fix the car, aftermarket clutch quadrant, autometer vac/boost gauge, dashcap, Walbro 255lph fuel pump,kirban adj fpr
88TC Black 5spd conversion, 160k+, with front mounted air filter, aftermarket clutch quadrant, autometer vac/boost gauge, dashcap, Walbro 255lph fuel pump,kirban adj fpr, svo t3, dual
2 1/4 in.
I got 245 on my rims that are the same width as stock. They look slightly buldgy but not bad
danadj Offline
ok thankyou.
-Derek
2 1/4 in.
Lx-tasy Offline
Hey Derek,
Go with a 245-50-16.Thats what I had on my Pony rims on my stang and they worked well.
Like Pete said, they will buldge a little on the side but look badass.
PM me your number again.
Chris
oldraven Offline
I have 245-50-r16 Toyo Proxes FZ-4's on mine, and I couldn't be happier. It takes 90* and full throttle in second gear to loose traction, and they never rub. Stopping is amazing too. Almost too good for the stock brakes.
They look meaty, but I wouldn't say bulgy.
http://img.photobucket.com/albums/v613/oldraven/tc1.jpg
I'd like to think my life has a soundtrack, and it sounds just like the white album.
1987 Turbo Coupe, 5-spd. Candy Apple Red w/ Charcoal Smoke Accents, k&n drop in, 2.5" duals. Stirring from her winter slumber.
http://www.cardomain.com/id/oldraven
http://www.cardomain.com/id/doasa
http://www.cardomain.com/id/jeepishltd
CAW!!
trbocoup Offline
I run the Potenza RE930 245/50ZR/16. I agree it's the best size.
Just because you're not paranoid,....Doesn't mean they're not after you!
