the timing belt was the problem i had started out with. the teeth were gone at the crank so i replaced the belt. the crank is at tdc position the dist rotor is at number 1 position and the cam is at the correct mark. put everything back together and the car will not start. I dont know what to do. I dont understand the timing stuff. i assumed that if everything was lined up right is should run, even if it ran rough, that would give me a place to start with adjusting the timing. any ideas. I need the car running by tonight. please help.
forrest of NC
forrest of NC
Quote: 88tc,metalic red, raven int. loaded except leather, has sun roof, k&n direct to vam for now. abused by previous owner, so I just need to get her running right before the good stuff. new timing belt, what a pita that was. forrest of north carolina.
