Am I understanding this correctly ? ,,The aux cam gear can be in any position just as long as the rotor will line up with the #1 sparkplug wire on the cap ?
This is my first time changing this belt I noticed the cam gear was pointing to the right mark instead of the center mark when it was at TDC , it was running fine so I dont know if it jumped or if its always been that way the belt looked good about 50,000 miles on it , however I did line it up with the center mark after several times of having something move I finally got them to line up but the aux cam moved a bit , so my ? is can I just turn my dist. to compensate ? Thanks
