ohioturbocoupe
Jul 2002
Bellville,oh,us
I am trying to time my turbo coupe and i can't get the timing right the belt slipped and now i don't know where to line up the timing marks where should the crankshaft mark point, and is there a mark on the auxilary sprocket which runs the distributor? and where should the cam pulley be lined up with?
see the following article: http://www.turbotbird.com/techinfo/CamTi...Timing.htm
Set the notch on the crank pully to the TC mark on the timing pointer on the #1 cylinder compression stroke. The mark on the cam pully should point to the center of the 3 marks on the back belt cover. If not the belt slipped and the cam is out of time. You cannot set ignition timing until the cam timing is correct.
[This message has been edited by Pete D (edited 01-31-2003).]
