Glenn 88TC
Lebanon, PA
I've had it this time. Need to take a long break. Really thinking about just walking away from it. I'm sick of the problems every time you touch something. Start out with a simple cam swap and many dollars($$$) later I end up with more problems.
Thinking of selling her. Would be put back to a stock head, eec, injectors and a t3 for the next owner. Should still run low 14's.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), Solid lifters, Esslinger roller cam #2277, Esslinger adj. cam pulley, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Spec stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
SteveX82
Toms River, New Jersey
I've attempted to sell my car at least 3 or 4 times so far, but something happens each time to convince me to stay with it until I get things worked out. Now that most of the bugs are sorted out, I really coudn't be much happier with the car.
What's wrong with the car now? Is it something that requires even more money to fix, or is it something that can be remedied with a couple nights of wrenching with you and a few buddies? You just have the makings of an incredibly powerful car and I'd hate to see it fall apart if it's just a matter of putting forth a bit more effort. Good luck with whatever decision you make, Glenn.
Estoril blue 1987 TC 5spd, 142k miles, PRofec B, walbro 255 hi-pressure pump, Bailey BOV, rod's header, spearco FMIC, t3/t4 50 trim / stage III .63, full 3" exhaust, eec-tuner, 55pph injectors, Nitto 555R drag radials
Best 1/4 mile: 13.389
Glenn 88TC
Lebanon, PA
Quote:Originally posted by SteveX82:
I
Imagine this new beautiful Esslinger adj. cam gear connected to your new Esslinger cam. Then imagine the tightened(and double checked) bolts on that cam gear coming loose on the initial test drive and moving all over the place. Then imagine the car not running(doesn't respond to the throttle at all) and some erratic compression readings(110, 110, 125, 90). Once the head comes off I don't think I will have to imagine the bent valves I will find. I really don't feel like looking at it right now.
methos
May 2001
Cynthiana, KY
Dude, you didn't buy that mech roller head and stuff that used to be on my car did you? because it will DEFINITALLY have atleast 2 bent valves with that monster .585 lift cam...
Methos
Jason Schaffer
88TC - 5speed, all options but leather and sunroof
Mods:
3.73 Gears and currently getting a transplant... Stay tuned for details...
AIM - Shizniblit
Jason Schaffer
Mods: 3.73 Gears
Finally getting it back together.
turbocoupes
Jul 2003
Aberdeen,Maryland
WOAH!!! YEH MAN!!! I'd be REALLY PISSED about now !!!hey Glenn...I'd do just that...cover her up...walk away...and get a little R&R...so it won't be ready for Carlisle...SO WHAT!!! can you get it done later???Just go to Carlisle...have a good time...clear your head...take sometime to enjoy the family (Momma probably would like that!!!)then when yer ready get back to it!!!Just remember..."BIRDS OF A FEATHER"...
Garry McVey Birdoprey always in flight... TBird TC owners are usually wingin' it
83 86 87 87 87 87 TC 87 XR4ti
Garry McVey "BIRDS OF A FEATHER" TBird TC owners are usually wingin' it
TC's 83 project, 86 donor for 83, 86 FUN street car daily driver with speed equipment from Red 88 donor, 87 blue to be stock street car, 87 red donor for blue and others, 87 red donor, 88 street and strip(now a donor) 14.01 chasin 13.0's, 87 XR4ti project,
Glenn 88TC
Lebanon, PA
Methos
It is the .489 lift Esslinger cam. Esslinger solid lifters and cam gear.
bluovalguy
Jun 2002
Omaha, NE
wow that really sucks. i definitely know the feeling of wanting to walk away from it, but i know you'll regret it down the road. youve got so much time and money in it... the only way youll ever "get back" what you have in it is with the gratification of having it run as awesome as it should once all the bugs are worked out and its dialed in. do what you need to do though.
88 TC 5 spd. T3/T04E 50, RR, ported everything, afpr/255lph pump, big front mount, 3.5" exhaust, alky injection.
Glenn 88TC
Lebanon, PA
I just walked away earlier. I'll go back at it again on Tues. hopefully. I just want to find out what is wrong and then it will most likely sit for a long time depending on what is wrong.
No car=no Carlisle. If I don't get it fixed I don't think I could walk around and be reminded of it all day.
BJL
Williamstown, New Jersey
Mr Glenn. though must not be sad, be glad, you KNOW you can get it fixed, just take a break, and think this trough once you get it aprt go form there, i understand you under stree with this, but still come to carlisle.
who is gona make fun of my car. lol, just take soem time off. that what i did most of the winter and got my blue car runnign great, just my stupidty ruined it, time, and patience. you ever need help im about an hour and half or so away im willin to travel, it wil be a laerning experiance for me. just let me know
Brian J Larkin
1988 Non-Turbo Turbo Coupe
med gray met. raven/gray interior, fully loaded minus leather and sunroof!
converted to N/A 2.3l by previuos owner, but its a nice driver with working A/C!
remote start, sequentail turn signals, 2003 stang muff. soon to have 3g alt, stereo, k&n, maybe ported intakes and manifold
1988 Turbo Coupe 5spd
gillis boost valve, k&n cone,AFPR, 255lph, HP pump,3G 130amp alt, 3.73 gears,mild torquie cam, factory DP, 2003 mustang take off SS mufflers and custom BJL 2 1/4 tails.
(needs a front frame pull)
Brian Larkin
88TC 330,000 miles
Slightly Modified
Matt S
Mountlake Terrace, WA
I'm happy to think that inside you know you won't sell it. You're too far into it, way too close. It didn't grenade. Just a couple valves. No holes in pistons it doesn't sound.
Minor details that are a huge setback.
My brother once broke a chain circle dirt racing a Fiesta, during warmup laps, the last race of the season, tied for 2nd overall....
They red flagged the track and made us find the chunks of metal in the mud. I found a rod.
Go have fun at Carlisle telling your story.
Sold it  *
