throttlebody leak
boosted85 Offline
So I pressure tested it again and found that the throttle body shaft was leaking air and the parts store doesnt carry gasket or seals do I need a new throttle body if so where do I get 1 or the seals or gaskets I've searched on here but couldn't find anything
Complete custom downpipe to tail pipe 3in exhaust, ranger cam, cran double valve springs, stock dsm bov switchin out for a good aftermarket, cone filter, fmi 2.5in piping, walbro 342hp, aeromotive fpr, fuel pressure 45 base, 17in cobra R's, steel braided oil feed line, 96lb injectors, megasquirt 1 v2.2, msd blaster 2 coil 86 t3 48, innovative lc1 wideband,
Robert Camp Offline
Punctuation and capitalization go a long way.
Robert Camp
boosted85 Offline
There is no punctuation when its talk to text on Ur phpne
gmaibach Offline
what kind of phone u got?
1988 Turbo Coupe 5 speed Red with Red cloth interior, K&N cone filter, Ported IHI turbo, ATR Header ported, Manual Boost Controller at 18 psi.
2013 Focus ST 2.0 Turbo, Buschur green filter, OCD Speed axle back exhaust.
boosted85 Offline
Droid. So does anyone know how to fix this problem or where to buy a new TB
Stinger Offline
There is punctuation in talk to text on your Droid, just say "comma" or "period" where you want the punctuation.
Also, just because you are using talk to text and don't want to go back and add text doesn't make it any easier for people to read.
Good questions get good answers.
www.Stinger-Performance.com
85 TC
85 SVO
86 SVO
87 Merkur
boosted85 Offline
OK with that said I will punctuate my post. Now does anyone have a solution for the issue I'm having?
Paulie Offline
Banned
Sir i think their is a company that re shafts and seals the TB. I cant remember where i read it. But i do have a question. How much can a shaft possibly leak?? And does it really make a difference. I do not want to sound dumb but i used a 5.0 TB on one of my cars with no issues and it did leak a bit. I cant see how a small leak can be a problem. Can anyone shed some light on this? Thank You and have a good morning
$19.99
Modern Automotive Performance
WORKS Aperture High Pressure Shaft Seals Evo
The shaft seals on a stock throttle body can only withstand a limited amount of pressure before they fail, especially as they get older. Even ...
Do a search over at TF..... someone over there found a seal that is a virtual direct fit. I forget the manufacturer / part #, but they are only a few $$ a piece.
boosted85 Offline
OK. Also is the SC throttle body fit without major modifying it.
