Evedell
Jan 2012
Auburn, Washington
07-16-2013, 06:32 AM
(This post was last modified: 07-16-2013, 06:34 AM by Evedell.)
Still having problems with my throttle sticking at 2-3k. Checked to see if the cable was hanging up, but when I pull on the throttle and let off (even gently) you can hear something smacking against itself... Is this normal?
Here's a video of the noise:
http://youtu.be/vTR6iF_E7ZA
1987 Turbo Coupe, T5, Stock 2.3t
converted shocks/struts
natmac3
Mar 2002
Aberdeen, MD
yup, nothing out of the ordinary there...
1987tc
RC Martin
Mar 2006
Colorado
Identical operation to my 84
BJL
Williamstown, New Jersey
its the pedal in the car bouncing off the cable inside the car and the sound travels through the cable.
Brian Larkin
88TC 330,000 miles
Slightly Modified
5.0TurboCoupe1988
Apr 2008
Broken Arrow, OK
yep, that sounds like slack in the cable causing the pedal to bounce. any codes? maybe the IAC is sticking open or you have a vacuum leak.
1988 TC 2.3/5-Speed, 148K
