Throttle Body
Keith Nubel Offline
I searched this and didn't find anything. Is the 65mm throttle body from a 1995 4.6 Ford the same as the Mustang that everyone likes to use? For that matter what year and models are the best to use?
Did Ford use a throttle body without the IAC?
1985 TC
Some Ford motors use a remote mounted IAC that isnt directly attached to the TB.
Cant help on the 4.6 TB question Sad
ratrapp Offline
i'm pretty sure it's not the same.i used a 60mm off of a 94-95 gt.most people call it a 65mm but it's only a 65mm if it's been replaced with a motorsports piece or an aftermarket one.
88 turbo coupe ported e6 kirban afpr forge bpv walbro 255lph stinger3" dp into 2 1/2 duals ultra flows bobs gutted upper with 60mm tb ranger roller cam.t-3 race engineering cam pulley gillis vale k&n cone 3.73s centerforce d/f 140 motorsports speedo and fms rear spoiler 17x9 cobras
88 trbo T Offline
94-95 T/B is a direct bolt on for the T/C? I would like to do this when i install the new HY35.
Brian Rothmund
Shelley Performance & Dyno Center
ratrapp Offline
it's not a direct bolt on but it's pretty easy.i bought the forced4 adapter kit and a friend gave me his stock tb when he went to a 70mm one.i did have to buy a new motorcraft tps but at least i know it's new.
88 trbo T Offline
can you tell me a price on the adapter and TPS???? Pls
Brian Rothmund
ratrapp Offline
the adapter was like $160 and i can't remember the tps price but i believe it was in the $60 range.
