Kuch
Sep 2016
Manlius, NY USA
I have my extra head ready to go to the machine shop for some work;
1, Plane the head surface and the exhaust surface
2, install new cam bearings
3, Install new hardened exhaust seats
4, cut both intake and exhaust seats for big valves
5, back cut intake valves
6, clean head
what are your thoughts on the expected cost for this work? I know there are always variables, but I asked one local place and he said about $700. I thought this was REALLY high, but I haven't had any machine work done in about 10 years when I rebuilt my 390 for the Galaxie. thanks
Mikey97D
Jan 2018
CONNECTICUT
My local machine shop I have donated motors before so I think he may have given me a break. I had my head rebuilt last year and I supplied the valve seals for under $250. I didn't have bearings replaced or big valve work.
IMO, considering the amount of work to dis-assemble everything and press the bearings out I wouldn't consider $700 being too high.
Now the really important question, what cam are you putting in it?
Kuch
Sep 2016
Manlius, NY USA
The head is already stripped of bearings, cam waiting to go in is a Boport 1.5, with his big valves and spring kit. I'll have to ask a few more shops around here for some other quotes, as I plan on putting it all together as well, I just need the machine work done.
Mikey97D
Jan 2018
CONNECTICUT
(02-17-2021, 08:02 PM)Kuch Wrote: The head is already stripped of bearings, cam waiting to go in is a Boport 1.5, with his big valves and spring kit. I'll have to ask a few more shops around here for some other quotes, as I plan on putting it all together as well, I just need the machine work done.
If they are just doing the machine work and pressing the bearings in that may be a bit steep price wise, IMO. I was under the impression they would be assembling it too.
Thor Power
May 2006
Austin, TX
Mine was around $275. That's kinda high!
88 Sports "Thor" disassembled
88 Grey 5spd Turbocoupe "Hooptie" ('09 Calendar) Parted out & crushed.(Tbird Heaven)
88 Black 5spd Turbocoupe Parted out & crushed. (Tbird Heaven)
88 Red 5spd Turbocoupe (newest member)
02 Lincoln Continental (road warrior)
06 Mercury Grand Marguis (custom duals like the Marauder)
