This is good clutch?
Import Killer Offline
I just ordered the powerbrute (borg warner?) clutch today, is this a good one? Also, in my new motor, what are the best plugs? I used AC delco rapid fires last time.
1987 Turbocoupe, black, 5-speed, all options besides leather and moonroof, 180K+ and running strong, MOMO shift knob and boot, mustang shifter (easier to reach), K&N cone air filter with cold air induction, dynomax super turbo exhaust, tinted windows, white faced indiglo gauges, sony XPlod and Pioneer speakers, Pioneer CD player, painted the faded red molding lines blue, painted interior parts blue, neon dome light, aftermarket foglights, runs great, eats rice for dinner.
Wanna see my beast? http://www.cardomain.com/member_pages/vi..._id=314900
1987 Turbocoupe
Painted sonic blue pearl
Ground effects w/S351 wing
17x9 Chrome Cobra Rs
255/45/ZR17 Kumho 712s
KYB suspension
K&N cone air filter, Gillis boost valve, T-3 turbo, ported intake and E6, A237 roller cam, MSD coil, Kirban FPR
Full 3" exhuast w/Ultra Flo muffler
Brute force clutch
White faced indiglo gauges
2 12" Rockford Fosgate subs and amp
I use Autolite 764 copper plugs.
Deathsythe Offline
Go with the Autolite 764's they are perfect for these engines.
Noname
Guest
The Brute Power clutch package was the first replacement clutch I had installed in my car. The clutch engangement was a lot tamer than I would have preferred, and it would slip by the time I reached 3rd gear whenever I was at the track. The clutch disc itself collapsed upon itself after about 7,000 miles. You will hopefully experience better luck than I did, but I can definitively say that I'll never buy another clutch from Borg Warner again. Instead, I stand firmly behind Star clutches.
Estoril blue 1987 TC 5spd, 136k miles
k&n cone in fenderwell, PRofec B electronic boost controller, kirban adjustable fpr set at 44psi base, walbro 255 hi-pressure pump, Stratmosphere Forge bypass valve, ported e6, volvo front mount intercooler, t3/t4 50 trim / stage III .63, full 3" exhaust, eec-tuner, 55pph injectors, dave compton a/f meter, Nitto 555R drag radials
Best 1/4 mile (before tuner, turbo, injectors, drag radials): 14.120 (with 1.983 60' time)
Best trap speed: 98.44mph
Glenn 88TC Offline
Amen!!
Glenn 88TC
current mods: ported & polished big valve head(1.89/1.59), ranger roller, custom upper and ported lower intakes, t3/t4 turbo, powerstroke intercooler mounted full size, 60mm throttle body, R.C. Engineering 42lb. injectors, MSD 6al, MSD Launch Control, MSD 8.5mm wires, K&N filter, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, full 3" exhaust with Dynomax Ultraflow muffler, Star stage III clutch, Hallman boost controller, Flex-a-lite adj. temp switch for stock fans, Weld Draglites with M/T ET Street 26x11.5/15
87 Merkur Xr4ti - daily driver
NO TC and NO headaches.
