BJL
Williamstown, New Jersey
why is that when i buya new head gasket he coolant port are just tiny holes on the gasket. my old gasket had them rusted through and matche the head and blcok ports and she didnt run hot, now she rnnign hot, so why do they make them jst small holes owudlnt biger passges cuase more cooling?
thats my $.02
*thoights of brian*
Brian J Larkin
1988 Turbo Coupe 5spd
Twilight Blue (loosk like midnight blue)
gillis boost valve, k&n cone, 3.73 gears,
junkyard resurection. have $100 dallor used motor, went 40,000miles no problem, blown head gasket as of 11/8/03 from doing the stuff at the address below http://natoubb.turboford.org/uploads/BJL/burnout3-9.jpg
Brian Larkin
88TC 330,000 miles
Slightly Modified
What gasket did you buy? What brand, p/n?
The water holes in the HG are that size for a reason. DO NOT enlarge them to the size of the holes in the block / head. The holes are small to balance out the coolant flow thru the block and head. I dont want to write a 5 page dissertation on the mechanics and thermodynamics of coolant flow to explain the small holes in detail, but take my word... dont enlarge the holes.
BJL
o i dotn want to enlarge the,m just wierd how rhe car ran cool befor enow its hot, onlyt differenc ei see
its a FelPro 1035, i used to blow apart the felpros, i had soem off brand one in the last head gasket job, it lasted the longest. so if it blows in the next 6 months im either finding a ford or cooper gasket, uhgh, head gaslkets suck!
Brian J Larkin
Brian Larkin
88TC 330,000 miles
Slightly Modified
Did you let it burp itself and then top off the coolant? Got enough coolant in the overflow bottle?
You only need two tools in life; WD-40 and Duct tape. If it doesn't move and it should use WD-40. If it moves and it shouldn't, use Duct Tape.
Bigamy is having one wife /husband too many. Monogamy is the same.
[This message has been edited by Pete D (edited 11-17-2003).]
Turbojet
Feb 2002
Connellsville, Pa. USA
I asked the same question at the machine shop. They said that the water jackets are restricted to slow down the flow of fluid to give it a chance to cool in your radiator.
The Family:
86
87
88
