the only reason im not crying at this point is my own pride....i cant afford all this
Cracker137 Offline
Hey Guys....
Well after having the bearing retainer fabricated, replacing the valve cover gasket, oil pressure sending unit, belt, tensopner, water pump, tstat and housing, ps pump,...(He list goes on....and most recently...ball joints tie rodes, bearing, pads, brake hoses I thought I'd finaly get to drive my TC for alittle while...well the next day I'm leaving my self a oil trail back(maybe my tc was worried I'd get lost) Sad Sad Sad
Now I currently belive that the oil pan gave, its rusty as hell in one spot, the rest is clean Sad I can't find one anywhere, rockauto has one for the 86.is that the same as the 87? Where do I get my hands on one for the 87? I searched and all I saw was something about an aluminum one out of a mustang, what's the deal with that? I would be interested in any kind of reasonably priced upgrades I can do while in the process while I'm in there
Sorry for the long, and proberbly badly written post, I'm frustrated, and my only means of internet is my blackberry right now. Thanks for and info in andavce, and for listening to me rant.
One of theses days ill get to show off my hard work....I hope
1987 Thunderbird TC
-T3 Turbo
-K&N
-3G 130 Amp
4cammer72 Offline
too bad youre not closer, id give you one
vinnietbird Offline
Brand new,and cheap.....
http://cgi.ebay.com/ebaymotors/OIL-PAN-NEW-OEM-COUGAR-LTD-II-MARQUIS-85-86-2-3-4-CYL-_W0QQcmdZViewItemQQhashZitem5ad7d5f00dQQitemZ390168178701QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAc cessories
1988 Thunderbird. No details will be given or spoken of.
vegas_ss Offline
I have a new ford aluminum pan with the oil sensor hole. I bought it off ebay a few years ago and I'll never use it... $55 delivered. I can get some photos of it if interested.
Cracker137 Offline
Sad Yeah....
I would interested, since my 87 has the low oil sensor.....not a big deal if that disappeared but i would like to keep it...id like to see some pics
So the one on ebay says Thunderbird 83-86...so the 87-88's DO use the same pan ?
1987 Thunderbird TC
-T3 Turbo
-K&N
-3G 130 Amp
vegas_ss Offline
I'll get photos up later today...
vegas_ss Offline
Here are some photos...
You may want to replace the gasket as it seems a little flat in some parts.
I also noticed the end by the drain plug is shaped differently... the stock pan is open in this area and this one is raised... not sure why... Also the red was done by the previous owner Wink
In looking around, it appears the raised area is for access to the torque convertor bolts... there is a plate that bolts to the pan to cover the opening (don't have that, shouldn't be needed) and I believe the pan is from a 92 or so ranger truck.
It has Ford part # E69E 6675C2A on the bottom.
http://natomessageboard.com/uploads/0000...600015.JPG http://natomessageboard.com/uploads/0000...600016.JPG http://natomessageboard.com/uploads/0000...600017.JPG http://natomessageboard.com/uploads/0000...600018.JPG
vegas_ss Offline
Cracker137,
Some additional info I've found out...
The oil pump and pickup are different, the stock pump/pickup hits the pan at a couple locations, but only a light amount of grinding on the pan is required to create clearance. Four of the pan bolts are longer because the bosses are thicker, two front and two rear. The loop on the back of the pan is to bolt to the bell housing specific to that pan. I don't know if the stock (TC) bell housing interfers in any way but the bell housing brace bolted on the back of the engine will interfere and have to be removed. There are two bolt holes that I don't think line up with the TC front crank seal housing, but I'm not certain on that.
Let me know if you want this as you have first dibs, but I have someone else who will take it if you don't.
Cracker137 Offline
Ok, thanks but I think im going to pass. Thanks for all the info it's really helped.
Still wondering, do the 86's and 87's use the same oil pan? or is it different?
1987 Thunderbird TC
-T3 Turbo
-K&N
-3G 130 Amp
BJL Offline
Moderator
at times these cars will get the best of you.... i have rebuilt 3 of these to driving condition and they have gotten me to the point of giving up. but if you step back and relax its all worth it.
having friend that share the same passion for this rare car is the best thing i think for keeping me going. i just pulled my blue 88 of of the sink hole it has been in for 4 years so i can bring to my house to dismantle it... looking at it and the smell of the inside brought a rush of memories (good and bad) of this car... i still remember the accident like it was yesterday. i vowed to it i would keep the car.. and i am... just it wont look the same.... it will become a different means of a car...
keep up hope. i have a few pans from various engines... 87-88. and i believe its only the low oil sender that are different
Brian Larkin
88TC 330,000 miles
Slightly Modified
