3bird
Oct 2003
Lee's Summit, MO
Where the heck does it plug in? It has to be by one of the hood hinges right?
After "only" 6 years I've got this car put back together. I actually got to drive it the other day! This stupid, meaningless light is the only thing that I haven't gotten put back and it's bugging me.
Thanks,
Kevin
JohnathanB
Jan 2013
thomasville NC
02-19-2013, 12:22 AM
(This post was last modified: 02-19-2013, 03:02 PM by JohnathanB.)
what year is your tc? if it is a 87 88 it should be by the passenger side hinge... maybe the plug fell down and you have to dig it back out
88tc 5spd new paint, cobra r rims, mods are :header back exhaust 3inc to 2.5 duals, jdm t3/t4 stage 3 turbo 20psi,jdm external wastegate, k&n filter on vam, fmic, new bottom end .422 lift cam, c4 trans being built
Not B Anymore
Nokesville, VA, USA
Mine is on the passenger side strut tower facing the turbo.
3bird
Oct 2003
Lee's Summit, MO
Found it, thanks guys. That was the last piece.
Not B Anymore
Nokesville, VA, USA
So when are you going to post the photos??? Maybe a little bit about your rebuild? C'mon, man!
3bird
Oct 2003
Lee's Summit, MO
Well, photos wouldn't be all that. It still needs a real paint job.
I fixed some rust over a rear wheel,
replaced the doors, fenders, hood and header panel,
replaced the windshield,
added a power passenger seat,
tripminder
A-pillar gauge pod with 30psi boost/vac and an A/F meter
Hurst shifter
Pioneer stereo and 6 new speakers
heater core
repaired a lot a hacked wiring
added cornering lamps
new clutch
mini starter from a Mazda pickup
adjustable fuel pressure regulator
Walbro fuel pump
replaced the air box with a K&N cone
3" downpipe and intermediate pipe to a 3" converter, Y pipe to 2 1/2" dual exhaust
Gillis valve of course
pads & rotors all around
new e-brake cable
BFG Traction T/A "V" rated tires
new rear main seal
timing belt
Probably several more things that I can't remember now.
I have a T3 still to go on, but I was tired of the car hogging up space in my garage and wanted it back on the road. I'll fix the bugs while I drive it, and I am oh so ready to be driving it again.
I need a new battery, insurance, safety inspection, renew the tags and I'm off. :happydance:
