I cured this problem, in part, for a while but it is back again...
Symptoms are pretty classic.
I have not pulled codes since it came back but, will do it today. Car starts OK, no high idle at all just runs. Then RPM will begin doing this up and down deal, rise a bit, then fall a bit, then a little higher and a little lower each time. The idle drops a bit first I believe, then the computer seems like it just can't keep up with the RPM fluctuations and and lags behing with it's corrections, a little too late unfortunately. It seems this way anyhow.
Idle falls to 800 from 1000 for instance, then computer over compensates and it rises beyond 1000 to 1200 or so to correct, then seems to realize that is too high so it lets it drop, but it goes too far, farther than before and drops to 700, realizes it and this time will go even higher, say 1400 or so, then falls again to maybe 600 this time and on and on going higher and lower until it enevitably falls "too" low and dies.
It will do this with the heater off/no AC clutching affecting it or not. When off, it only prolongs the up/down cycling, but it still dies..
I replaced the distributer rather than mess with the PIP only, then the TFI. It was cured... for a while. I believe it is one or the other, or both again, and wish I had the money to buy a half a dozen TFI modules so when it does idle again I can then check the other modules to find out if any of the others are defective.
Even when the thing does idle correctly, stable and such, I have never had either of my 88 TC's run on high idle when cold outside... and this is VERY frustrating because they will always run a little lower RPM from added friction even running Mobile synthetic, and any little hickup or engine load can cause idle to fall just enough for them to occasionally die. Like the fan cycling on. It doesn't seem like I should have to raise the base idle as they both already run at ~900-1100 RPM. I would expect to see 1500+ RPM for a minute or so then see it scale back but this just never happens. It's just something I don't have to deal with with other rigs. Mainly it is because the wife has to put up with it, that it irritates me. It is just not dependable, and I know it has to be something simple.
The IAC has been cleaned and I see no reason to replace it but feel like throwing a bunch of new parts at it to see what happens.
Anything I can do to get this to run higher on start up?
Brent
