teves brake system diagrams
plstktnkr2 Offline
does anyone have a diagram of the whole brake system so I may order brakes parts to save my '88 'bird? I have a leak and I need to know what parts I need to aquire
rick
All Ford all the time, 4 stangs 1 lincoln 'vert and 1 turbo 'bird
Where is the leak? The only parts on the MC itself that can be replaced are the plastic reservoir, the level sensor / cap on the reservoir, the pressure switch, and the pump motor. The internal stuff in MC itself cant be serviced at home. They are very complex, and require clean room conditions for assembly. Your best bet might be to get a complete working assembly from someone parting out a rust bucket.
plstktnkr2 Offline
there is a line leaking on mine and they have to find it first
Do you mean one of the 3 brake lines coming out of the botom of the MC is leaking? If so, just replace the line. One relatively common leak location is the PRC pressure switch in the line to the rear brakes under the MC.
There are 2 (if I remember correctly) flexible "rubber" (no clue exactly what they are made of) lines on the MC between the reservoir and the MC body that could leak. These lines are under virtually zero pressure. Those can be replaced with the correct type of material.
