Cracker137
Oct 2009
Carleton, MI
So I was driving home, I just replaced the thermostat and the water, My temp gauge was riding on the N-O of Normal...what is really weird to me is when i turned my headlights off it went down to around the R-M and when i put them back on it went back up. Whats going on here?
I'd be interested in a good answer to this as well because I noticed my temp gauge reads higher when the lights are on.
Chas K
turbospoolin23
Jan 2007
Canada,AB
My temp gauge also reads higher when lights are on, it's close to the red sometimes even dips into the red.
UglyBird85
Jan 2009
Norfolk, Va
Mine did too and it worried me so I just got an autometer electronic temp gauge. Comes with a new sending unit and everything. Car rarely gets above 195 degrees and I ALWAYS drive with my lights on.
---Justin
87 Burgundy TC 5spd. K&N Cone filter-Walboro 255HP-.60/.63 Garret T3-Gillis @ 18psi.
SHELF: NPR FMIC-Ford Racing 42# injectors-Tripminder-
Did the oil pressure and gas gauge go up and down with the temp gauge? If so it's the IVR. I've noticed over the years that a load on the system (headlight etc) can make it act up.
turbospoolin23
Jan 2007
Canada,AB
Delete (double post)
turbospoolin23
Jan 2007
Canada,AB
only my temp gauge goes up when lights are on, it doesn't effect any other gauges. My oil pressure gauge goes way down when I'm at idle, lights don't effect it. I also have aftermarket gauges and all is good. My fuel gauge doesn't work at all, I think I need a new sender.
Cracker137
Oct 2009
Carleton, MI
No the only gauge that reacted on mine was the temp gauge, that why I really wasnt thinking IVR since it was only the one gauge...right now im testing my alternator to see if its good since im pretty sure its a problem with the gauge vs the engine actually overheating....seems like its common problem though from the other responses.
alanjlambert1472
Apr 2010
New Jersey
Yeah, come to think of it mine mostly runs higher at night... could be a headlight thing too..
Also mine seems to creep down when the car sits at idle..back almost to normal, then it goes back up slowly as I start driving..
But still it isn't overheating, as per the engine block being normal temp and the heat taking the normal time to get warm.
1986 Ford Thunderbird Turbo coupe
all stock, hacksaw muffler delete, 124k miles.
1985 Ford Thunderbird Elan 5.0, 172k miles, shift kit, true duals, stock otherwise. **SOLD**
Kerry
Nov 2008
Savannah, TN
My TC doesn't do this but I think it must be sort of a ford thing. I have two fox body mustangs and they both run at least two notches higher when the headlights are on.
Kerry
1988 Turbo Coupe
5 speed
