(This post was last modified: 11-04-2019, 08:17 AM by andrewjs18.)
Engine:
Replacing Valve Cover Gasket
Horsepower Calculator
Compression Test
Head Gasket Replacement
Cam Timing Belt Replacement and Set Up
Valve Spring Compressor
Distributor Cam Wear
Vam Idle Adjustment
Rebuild a T3 Turbo
Fuel:
Fuel Pump Diagnostics
Fuel System Diagnostics
Turbo/Intercooler:
Installing a T3 on an 87-88 TC
Forced Air Intercooler Fan
Super 60 Flow Analysis
Turbo Care - Oil Change
Performance Mods:
Beginner's Mods for HP
K&N Cone Install
K&N - Front Mounted
Cold Air Induction Install
Gillis Adjustable Boost Valve
Transmission:
AL4D Transmission Upgrade
86 TC Clutch Replacement
Drivetrain:
Rear Axle Swap
Power Steering Fix
Suspension/Brakes
Converting ABS to Vacuum Assist
Adjusting the PRC for Drag Racing
87-88 TC Rear Caliper Rebuild
TEVES II Electro-Hydraulic Braking System 87-88 TC's
Maintenance/Care:
Turbo Care - Oil Changes
Detailing your TC
Vent Window Latch Repair 83-86
83-86 Weather Stripping Repair
Specs/Info:
83-86 TC Specs
87-88 TC Specs
Vin # Decoding
87-88 TC Part Numbers
1988 Turbocoupe Ordering Guide
Electrical:
Sunroof Won't Open
Unable to Retrieve EEC codes
Speed Calibration using Desktop Computer
TFI - PIP Replacement
Idle/TPS Adjustment
3G Alternator Install
Sensor and Device Locations
Retrieving EEC Codes
Running Codes from in-car
EEC Codes
Indiglo Gauges
Pillar Mount Gauge Pod
Dim Headlamp Fix
Installing Headlight Relays
Gauge Flux Fix
New Design Solid State IVR
Integrated Relay Control Module (IRCM) Trouble Shoot & Repair
Remote TFI Mounting
Remote Mount TFI
Heating/Cooling:
R12 to R134 Conversion
Heater Core Replacement
Cooling Fan Test
Cooling Fan Switch 85-86
Radiator Fan switch Install
AC Compressor Clutch Disassembly
Compression Test
Vam Idle Adjustment
Rebuild a T3 Turbo
Fuel:
Turbo/Intercooler:
Performance Mods:
K&N Cone Install
K&N - Front Mounted
Transmission:
Drivetrain:
Rear Axle Swap
Power Steering Fix
Suspension/Brakes
Maintenance/Care:
Detailing your TC
Specs/Info:
83-86 TC Specs
87-88 TC Specs
Vin # Decoding
Electrical:
Sunroof Won't Open
Idle/TPS Adjustment
EEC Codes
Indiglo Gauges
Dim Headlamp Fix
Gauge Flux Fix
Remote TFI Mounting
Remote Mount TFI
Heating/Cooling:
Cooling Fan Test
https://tbirdcougarparts.com
-Andrew
-Andrew
