My 1988 Turbo Coupe isn't starting
It was running fine (mostly), then about 2 minutes after I started it a couple days ago, it just died. Kaput. Nothing. It cranks, but doesn't catch or fire at all.
For a couple weeks before it died, the tach was acting funny -- jumping several hundred rpm, while the engine was running steadily. It would do this at idle, or mostly when I was accelerating. The engine never missed, the tach would just momentarily jump up to a higher rpm.
Is there any way to remove the TFI module without taking out the distributor? It seems like it should be possible, but every set of instructions I've found says to remove the distributor first....
Is there a way to test the PIP, preferrably without removing the TFI?
So, I'm pretty sure it's not the fuel pump, timing belt, or coil. I don't think it's wiring. Is there anything else besides the PIP or TFI that could be the problem?
here's what I've done so far:
- Confirmed the fuel pump runs. I can hear it cycle for a few sec when I turn the key on.
- Checked for a spark from the coil. I just unplugged the lead from the distributor and laid it up next to the alternator, and looked for a spark. (I was by myself, in a parking lot away from home.) No spark.
- I replaced the coil. A pretty easy job to do in a parking lot. I had my fingers crossed, but it didn't make any difference.
- I checked the timing belt. It's not broken.
- I had my buddy tow me home, late at night, on back streets. No lights. (My battery was dead from cranking too much.)
- Recharged the battery.
- Confirmed +12 at the coil when the key is on.
- Confirmed no ground signal to the coil while cranking, using a 12V lamp, connected between the signal wire from the TFI module at the coil connector and +12 on the battery, with the coil connector still plugged in. (When the key is off, the light comes on, and I can hear a *click* somewhere when I connect and disconnect the light. Back-feeding a relay?)
- Confirmed continuity between the coil connector and the TFI connector.
- Confirmed +12 at the TFI connector battery terminal when the key is on. (TFI connector unplugged)
- Confirmed +12 at the TFI connector Start terminal during cranking, with connector unplugged.
- With the connector still unplugged, tried to check the Gnd wire at the TFI connector, using my test light connected between it and the battery +12 lug. No response, with the key in any position. Measured 7.9 V between battery + and TFI gnd using a multimeter, with the key on. 12 V measured between batt + and TFI gnd with key off.
- Jammed a paper clip down the gnd wire of the connector and plugged it back in. Now it reads 12V when measured to batt+ with the key on!
It looks like the TFI and coil have power and are connected properly. Is there anything else I can check, or is the TFI confirmed bad?
thanks,
Eric
thanks,
Eric
stock (mostly) '88 TC, slowly deteriorating....
