TBird running!!! Well Maybe not..
Thor Power Offline
Well now that I got my TBird running, (remember all I did was drop in a dizzy and retimed the car) it's now pinging (tapping) everytime I drive it. Has the sound like there isn't any (or low) oil in the car. Drove it to San Antonio and back to Austin, and it was tapping the whole time. Something is wrong. It wasn't making that sound before. Well after looking at it today with some car nuts, it's believed it's coming from the #1 piston area. Possibly that lifter being loose. Well tomorrow I will tear into it. I thought it could be timing issue but it was timed correctly. Fires up fine, just when I start driving it, it makes the tapping sound. You could almost hear the sound coming from the front (#1 piston) area. It increases when I accelerate also.
88 Sports "Thor" disassembled
88 Grey 5spd Turbocoupe "Hooptie" ('09 Calendar) Parted out & crushed.(Tbird Heaven)
88 Black 5spd Turbocoupe Parted out & crushed. (Tbird Heaven)
88 Red 5spd Turbocoupe (newest member)
02 Lincoln Continental (road warrior)
06 Mercury Grand Marguis (custom duals like the Marauder)
FastN'Fried Offline
Sneaky intake leaks can cause pinging, but I think that's usually only under load. Is it clacky? If it has a rythem I would assume it's related to the engine turning, mechanicaly related, maybe a rocker coming loose. If it seems sparatic I would guess ignition. Maybe it's time for a set of anti-pump lifters?
1988 Canyon Red Turbo Coupe
Carrillo pistons +.030, ARP hardware, 3in exhaust, and a magnaflow
Does the engine have a slider cam? If so, have you been using an oil with a high ZDDP content or using a ZDDP Additive? Modern oils have severely reduced Zinc content and the lack of Zinc seriously accelerates slider cam wear.
Thor Power Offline
It's clacky. I think something is coming loose.
Dan S Offline
Pull the valve cover and have a look at the cam. See if it shows signs of wear (deep ridge) from the followers. If there are no signs of obvious wear, you may have a problem with a lazy or worn out HLA (hydraulic valve adjuster) or two.
If the cam is worn, then the entire valve train will need attention. You will also need to follow what Jeff stated above.
Dan S
1972 Ford F-100 SWB Styleside
2015 Lincoln MKC 2.3 EcoBoost AWD
Thor Power Offline
I'll be pull the valve cover off tomorrow (today...it's 2:17am). I have a good spare cylinder head from my other T-Bird that was error free. I might just swap them out then repair whatever damage is on the cylinder head I'm pulling (unless it's a simple repair and I can do it without pulling the head)
FastN'Fried Offline
If you wind up wanting a reman, its cheaper (in my area) to skip the machine shop. PO of my bird stuck a remanned turbo head from rockauto on and I haven't had any problems. Car fires up with a few turns of the starter, them valves is sealed Big Grin
