Is there a parts list for a conversion to at t3t4 conversion from the IHI? I bought a 50 trim t3t4 then found out I needed a different rear down elbow from a t3. Then realized I needed a different oil return line. After lining everything up now the hood wont shut and the front intercooler bracket wont line up or able to use the exhaust manifold bracket......am I doing something wrong ????
o4 mach-1,white,4at 1 of 169 ,MAC air filter and x-pipe, SCT tune / o9 BMW 328 M-SPORT, white, 6at/ 87 Turbocoupe ,white,4at,KIRBAN afr,GILLIS boost valve,Garrett/SVO T3,cold air,3" STINGER down pipe and tail pipe, DYNOMAX ultra flow stainless muffler, Walbro 255L fuel pump,cleaned and flowed injectors,STINGER BOV, built A4LD trans w/all
4x4 Explorer guts, K245/F57FA torque converter.
I did notice the the t3 exhaust outlet is 3/16 smaller in outlet diameter than the IHI. And the stud spacing is also wider than the IHI but it still bolted up to the Stinger down pipe. I found it strange the smaller turbo ihi with a smaller exhaust wheel had a larger I'd down elbow.
Not B Anymore
Nokesville, VA, USA
I'm not real familiar with how the IHI is set up, but I know that the compressor housing on a T3/T4 is significantly larger than a baby IHI, which is going to push your top-mount up. I don't know if there is any way to correct that or not. How much clearance do you need? Might need some surgery on the IC... :dunno:
I can tell you that on my car, which started life with a T3, the T3/T4 was a direct swap without having to change anything else on the car. That being the case, I think THIS ARTICLE could be of some assistance to you.
Do you know of any one who takes off the ramair plastic for the intercooler ? Im guessing im going to have to get a front mount intercooler from Stinger.......
Dan S
Jan 2003
Harrisburg, PA
My ramair system is off and I'll second the FMIC. I have a new FMIC on the shelf waiting for install with a new turbo.
Scott Mabe
Nov 2013
Virginia
I've thought about when I get a fmic I was going to fab a piece to use the scoops for the air inlet for the turbo.
1987 Turbo Coupe
1990 F-250HD 460ci
How much rain water do you get in the engine compartment when driving without The plastic ram air in place ?
Dan S
Jan 2003
Harrisburg, PA
I thought "B" would answer that for me! My car doesn't go out in the rain!
:pimp:
Not B Anymore
Nokesville, VA, USA
Dan S Wrote:My car doesn't go out!
:pimp:
Fixed it for ya!  tickpoke: :rotfl:
Ah.....got you
Fyi the hood shuts without intercooler intake system on. Now to put on wastegate actuator and see whats up....
