Qwertys
Mar 2004
California
sorry for asking this question, i did some searches but didn't find anything besides where to buy them.
what entails a rebuild kit, how hard is it to do, and what is the BEST rebuild kit i can get?
Can I upgrade my T3 with ceramic or ball bearings or would that require a while new turbo (center housing, shaft, balance, ect...)
The shaft and impellers seem in good shape (very little play) though i want to rebuild it before i put it in just in case.
is there any special tricks and tips? i already got the exaust housing out...
also while on the subject, I am custom fabbing water lines to fit my 88 for the T3 turbo. i was able to make the feed line easy enough but where do i put the return line? it seems the old line to the block is WAY too small.
'85 TC BPV and Ford FMIC
Qwertys
Mar 2004
California
anything? all i can find are the turbo rebuild kits on ebay, and i dont know if i can trust that. and the other kits i find are 150$ for the exact same parts?
Qwertys
Mar 2004
California
oh well. i went ahead and bought this kit: http://cgi.ebay.com/ebaymotors/ws/eBayIS...7929083858
as well as the braided oil feed and return lines.
we'll see how this works out...
Qwertys
Mar 2004
California
i bought the kit. all is well except i cannot get the nut on the shaft off. the turbine has a very wierd triangly nut on the end and i cannot get something to stay on good enough to get the compressor nut off. any ideas on how to do this?
evintho
Dec 2003
Santa Rosa, CA.
Sorry, I'm a little late, but here's a good link.
http://www.turboparts.info/pages/634268/index.htm
I wish someone would chime in 'cause I'm about to rebuild my T3 also. Come on guys, anyone, anyone, Bueller?
Proverbs 3:5
Check out Thunderstang!
"anyone, anyone, Bueller?" ha, that cuts it, that movie is great.
-88 TC Black
-97 Pathfinder
Qwertys
Mar 2004
California
well i bought a nice rebuild kit off ebay. had lots of parts. i was rebuilding the turbo last night, and was in the process of putting it back together. theres a little ring around the shaft on the turbine side i guess its called the piston ring?
well, while trying to put the shaft back it, i bent that ring, and destroyed the shaft and the center housing.
oh joy. a little 1$ part just cost me 400$ or more. what a day. so now i need to find a shaft and center housing, then send the shaft out to get balanced, then shoot myself in the head one more time.
evintho
Dec 2003
Santa Rosa, CA.
Ya know, yours is not the first horror story I've heard, when it comes to rebuilding turbos. I'm thinking of maybe going this route. $240 ain't bad.
http://extremeturboshop.com/
Proverbs 3:5
Qwertys
Mar 2004
California
I'm actually thinking i'll just go buy a new center cartridge (including wheel and all) and go for BALL bearing. it shouldn't be much more then 500$.
You can buy just the center housing minus the backplate on ebay for about 70$.
so... i can also go that route or sell what i got. if someone has a busted compressor wheel but a good turbine wheel and shaft then this could be a good deal...
what you get out of turbo shops is if the housing is bad they will bore it out and put in oversized bearings, and also balance the wheel.
Qwertys
Mar 2004
California
well a little update. i bought a GT3071 Dual Ball bearing turbo from Scott. really nice guy and helped a lot in deciding which turbo to get.
I dont have the exact specs with me right now and i bet Scott could give a more accurate description, but i remember its a T3/To4E Hybrid and should support a max of 450 HP. with a BB setup it should spool better then anything out there (and run cooler).
Can't wait to get it and the car back up and running (might be a few weeks).
In addition, all the other work i will be doing includes: replacing the bumper, both fenders, and perhaps ported intake and K&N Cone in the fender.
others to include:
Watercooled IC, Gillis Valve, 3" Exaust, Walboro 255 pump.
Current setup is: Kirban AFPR, 8.8 4.10 rear, new clutch, new Leather interior, Autometer Boost gauge, Autometer O2 gauge.
