Metal381
Apr 2003
Uniondale, N.Y. Usa
Hi i just got a used to t3 turbo from an 85 svo. It is the m10 , .60 compressor housing. The question is this one came without the i let adapter from the Vane air meter hose. Will the one from my ihi fit? It is the two bolt elbow, i am reffering to. Thanks!
Anthony M
Aug 2002
Toledo, Ohio, 43613
Yes the IHI elbow will fit [Image: biggrin.gif]
Anthony
88 TC, T3, Volvo IC
The ihi inlet will bolt up.
Metal381
Apr 2003
Uniondale, N.Y. Usa
WHEW!!! Thanks guys i was nervous for a minute there that i was gonna have to go huntin! Thanks again!
Dan E
Greensboro, NC
Not only will it fit...but you would have wanted to change it anyhow...since the one on the SVO T3 didn't have any vacuum nipples [Image: biggrin.gif] !
Dan Eaves
Dan Eaves
Metal381
Apr 2003
Uniondale, N.Y. Usa
Thanks for the info guys i am in the middle of swapping heads and the turbo swap. My baby is in the shop waiting to be reassembled. The only thing left it to put the head and all back on and elongate the downpipe flange bolt holes. Thanks!
