t3/t4 hybrid turbo fitment issues
brokenbirdy Offline
I installed a hybrid turbo and now the damn intercooler sits to high and my hood won't close
BigJake Offline
Post some pic's so we can see what's going on.
Kuch Offline
Broken, I installed a T3/T4 last summer and I had to clock the compressor side to get it to line up. I am still using the factory intercooler and couplings as well. I could not get it to sit low enough to reuse the factory mounting brackets however, but it works fine.
brokenbirdy likes this post
brokenbirdy Offline
(04-09-2020, 12:57 PM)Kuch Wrote: Broken, I installed a T3/T4 last summer and I had to clock the compressor side to get it to line up. I am still using the factory intercooler and couplings as well. I could not get it to sit low enough to reuse the factory mounting brackets however, but it works fine.
I clocked mine but no luck. do not have mounting brackets. I can make it fit with a little cut and trim work.
Kuch Offline
Ok, that is interesting, some pics if able may help us out.
brokenbirdy Offline
(04-09-2020, 04:29 PM)Kuch Wrote: Ok, that is interesting, some pics if able may help us out.
Finally all the quirks worked out, Had to cut 3/4" off turbo snout, 1/2" off intercooler intake snout and 1 1/2" off rubber coupler in order to make hood close.
88 Turbo Bird 5 speed, Intake and exhaust mods, T3/T4 hybrid turbo at 20 psi, Cold air cone filter, manual boost controller, subframes. Still being refreshed.
Kuch Offline
Hmmm, that looks very similar to how mine sits, can you turn your compressor housing a little more CCW to bring the outlet a little lower? Yours looks almost horizontal on the outlet, and from what I remember about my install, mine sits a little more offset. I can grab a pic this afternoon and post it for you
brokenbirdy Offline
(04-23-2020, 02:39 PM)Kuch Wrote: Hmmm, that looks very similar to how mine sits, can you turn your compressor housing a little more CCW to bring the outlet a little lower? Yours looks almost horizontal on the outlet, and from what I remember about my install, mine sits a little more offset. I can grab a pic this afternoon and post it for you
Tried that and it just didn't work.
Kuch Offline
Here is what mine looks like with a T3/T4 .50 trim.
Attached Files Image(s)
BJL Offline
Moderator
How does the spool time compare to the T3 KUCH?
Brian Larkin
88TC 330,000 miles
Slightly Modified
