I was looking for a larger opening turbo mount gasket and found this on RA. The opening on it measures 2.5"w x 1.8"h and you can see the difference in size when overlayed on a stock T3 gasket. This wold allow us to open up an E6 opening even more for better flow than a stock replacement gasket would. It's a Mahle F7414, thought I wold pass it along.
I put it on both my new Gnari and the stock E6 I have. There is a little I can still take out of the Gnari,but the E6 can have quite a bit removed with this gasket.
