T3 Oil Return Line
SteveX82 Offline
Before I positively decide on replacing the ihi turbo on my 87 TC with an older T3, I wanted to check one last thing. Exactly how is the oil return line different between the two turbos? Would it be possible to rig up a series of connections to make the existing line work or would I have to shell ou the $100+ for the proper return line?
maroon 1987 TC 5spd
gillis valve set at 18lbs, k&n cone on VAM, removed A/C belt, unbolted exhaust at track,
best 1/4 mile: 15.10 @ 89.25mph
UPDATE: car blew the turbo on 8/17/01, so it'll be off the road until next summer when i can fix it.
Keith Nubel Offline
I believe the flange is different were it bolts to the turbo. You can get them new or find one in the bone yard.
85 TC 5 speed, K&N filter charger, Ranger Roller cam, 3" exhaust system, manual boost valve, large VAM, SVO PE computer, front mount intercooler, underdrive pulley, ported upper and lower intakes,flow matched injectors, ported E6 manifold, 245/45/17 wheels & Tires
1985 TC
Keith is right. The turbo flange end is different. Be sure to pressure check a used line before you install it, if you go that route
Turbocruiser88 Offline
Why even pay $100 when I'll give you one for $40 + shipping? [Image: smile.gif]
Les T.
88 TC - Light Sandalwood/Black 5sp. *RIP* Precision SC-50, A237, Stage 3 clutch, Ported E6/Intakes, 54k motor
94 BMW 540i
92 Saab 900s Vert
82 Stang GT - T-Top, Soon to be 2.3T - that engine shown above!
80 MB 300SD - Turbo Diesel
96 Explorer - 5.0 GT40 AWD, Soon to be turbo'd
SteveX82 Offline
I'll make sure I'm actually getting a T3 first and am not getting the return line with it. If not, i'll probably take you up on your offer. Thanks.
maroon 1987 TC 5spd
DennySweet Offline
Turbocruiser, If that line dosent sell I will take it! LMK Denny
88TC,87TC,,86S-10,82Toyota 4WD,3-88S-10Blazers.
