turbocoupeterry
May 2001
lima,ohio united states of america
i was wondering if ne one has attemted if its even possible to put t-tops in our birds or maybe even put a supra or corvette stlye top and just have one big removable section, or is the body not equipped to hold up if i do this
thanks
terry
88 tc, new tires and a k&n filter fender mounted
BJL
Williamstown, New Jersey
the only reason i can t think of why it wasn't done was because the door window track, , how the door isn't like a convertible door, , but since mustangs came off the line with t-tops that had that part of the door cut off, it is possible, but i have thought about it, you would need subframe connectors, well ,just to be safe you should use em, but t-tops would help out allot with theses cars, since there are closed in the back and the air sits in the back and doesn't circulate as much. I have seen one tbird that was a convertible and then the cougar ( www.coolcats.com) hope this helps, and if you ever get plans up to do one, ill be waiting in line for it to be done!
Brian Larkin
88TC 330,000 miles
Slightly Modified
Matuszak88tc
Oct 2003
Holloman AFB
I went to a body and collision shop,they told me that be cause of the way that the car was designed. He said in order to put t-tops in I would have to have a custom set of doors made up from fiberglass, put in sub frame conntors installed and strut tower brace put in. See I asked for a "targia" top
you know like a corvette has. one solid removeable hard top that went from one door to another. Any way that was one guts opinion.
