t-bird hates firing up
junkedturbo Offline
I just bought a 1985 turbo coupe about a month, when I first got it the poor thing had been sitting in a trailer park for about a year and A half. The timing cover was missing and the timing was off so I went down to the junk yard and picked up a timing cover and got the thing running. Now i have the problem down to were it just doesnt want to start up right away for me but when it gets started it runs just fine. The bird will only start to fire up when I almost have my foot on wide open throttle, then I have to let my foot off the gas immediatly, then it'll run retarded then fire right up. But over the day of turning it off and on it'll try to start but will die out right away and will some times kill its self at low idle, and it'll smell like gas when trying to start it, I've put in a new starter, starter relay, bus battery, new alternator, MSD coil, Axcel wires, the 5th set of motorcraft plugs, a new throttle positioning sensor, and replaced the gaskets and hoses. My friend set the TPS and checked the vam and finally I scaned the codes and got a 12 34 51, did it two more times and keep getting 51 which if im right means that my temp. senser is at fault, I went to the auto store and they didn't have the senser so I went to junk yard and pulled off about three of them from diffrent T-birds, is there a diffrence between the sensors and would that fix the starting up problem? I also found out that my car had bigger injectors put in it, there green and made by bosch so I pulled the injectors from the only t-bird (1986) there, are they right ones? Any help would be great, Thanks!
Any 86 TC should have brown top injectors - 36 #/hr
Was the car warmed up when the codes were pulled. If yes then suspect the ECT, between the middle two injectors, or the wiring. A bad one can have a noticeable effect on performance
junkedturbo Offline
thanks, I put on the smaller injectors and a diffrent ECT and the car starts right up now. Would anyone know were I could get a wiring diagram of the alternator conecting to the battery? I had my alternator checked and its cranking 14.8 volts but just isn't charging the battery, I thought the battery was bad (it was) so I put in a new one and still no charge?
