Looking for a rebuild kit for the 87-88 T-5 trans . Anyone has a site and or the best deal for the buck , let me know .... Thanks
DW
Bungy
Oct 2010
Minnesota
You could also check with www.5speeds.com They have a "peelable" shim that makes setting endplay a breeze.
Another possibility is evilbay. Might be a little cheaper, but you don't really get any customer support there either.
1986 TC 100% Stock
"Nitrous is for guys who can't build motors"
OK, thanks. its for a friend that says he hears noise from the tail shaft, tail shaft bearing ?? if so ,, can that be pulled off .. the tail housing to fix the tail shaft bearing . Not sure . have never had one that went bad , he did say that is has high miles on the car, 160K . Thanks for any help . D.Wilder [email protected]
DW
There is a special tool that allows you to remove / install the tailshaft bushing in 5 minutes without removint the tailshaft. Its around $100, and worth it is saved time & hassle.
OK, got it ...... thanks for the help . I believe my friend is going to buy the tool . D.Wilder
DW
