I bought a T-5 transmission from 83 TC for spare part. It's working well and quiet but has play in input shaft. How much play can be considered "normal". In this case there is about 3 mm play measured from the end of shaft. Is this too much?
Probably it's input shaft bearing which causes play, can it be easily changed or should I disassemble the transmission? Can I use input shaft bearing from V8 T-5?
In some sources T-5s from 1985 up are called "world-class". So how is this older T-5 different than world-class T-5. Can I for example use Ford Racing rebuild kit with it?
Sorry, quite many questions! Hopefully you have strength to read them all...
Lauri Salokangas
Tampere, Finland
1988 T-bird TC 5-spd (ex- automatic), black with dark blue/ grey interior.
85k miles, K&N filter, adjustable boost, Ford Racing 9mm plug wires, Philips hi-fi system with CD-changer. ATC, moonroof, dual power seats, premium sound, keyless entry, autolamps/ dimmer, cornering lights, power antenna
Lauri Salokangas
Tampere, Finland
Lauri Salokangas
Tampere, Finland
1988 TC 5-spd, black with raven int.
K&N, CAI, Gills, Walbro 255lph, Kirban AFPR, BOV, 3" Stinger exhaust. Rebuilt diff and trans, 3G alt, Energy Suspension bushings, KYBs
1984 Mustang SVO
Tampere, Finland
1984 Mustang SVO
