BradM
Dec 2020
Barrington, Illinois
I wasn't clear about this. I re-used the oil supply line and drain line. Stinger sells a drain line kit but they couldn't tell me if it would fit with the Gnari. The OEM supply line just needs to be reshaped with a tubing bender. I believe the drain line required flanged bolts to help apply even pressure to the fitting because the fitting face was a bit smaller than what the turbo wanted. No leaks.
01-16-2022, 03:20 PM
(This post was last modified: 01-16-2022, 03:52 PM by BigJake.)
Here's my 4 cent's
Some Ebay turbo's work good and some don't, all depends if you drive your car like you stole it LOL. I call it my China Rose.
I now run a 63a/r T3T4 Garret 5 bolt turbo which works great on my combo at high boost.
1987 Thunderbird Turbo Coupe 5 speed Boosting 25 PSI with Boport/Stinger parts !
01-16-2022, 03:31 PM
(This post was last modified: 01-16-2022, 03:37 PM by BigJake.)
Here's how I ran my breather hoses from the block and valve cover to the intake.
I've seen a post or two on Facebook in the different groups who say they are using Big Rs T3 50 trim and they are loving it. There was no details on the install or anything, but I can't imagine a guy like him that supports the platform so much sell something that's crap to ruin his name!
I plan on buying one of them sometime next year, but first I'm going to try out one of his Ranger X regrinds with some Boport drop in springs.
Cleven
Nov 2021
Arkansas
(01-16-2022, 09:25 PM)Svtfiend Wrote: I've seen a post or two on Facebook in the different groups who say they are using Big Rs T3 50 trim and they are loving it. There was no details on the install or anything, but I can't imagine a guy like him that supports the platform so much sell something that's crap to ruin his name!
Iv seen a few people that daily his turbos with no issues on a few Facebook groups when I had Facebook. Just putting everything together in my head before i think about upgrades. main thing is if I really need a stand alone system for my minimum power gain goals im looking to reach. Digging around old posts really helps me get a grasp on things.
Cleven
Nov 2021
Arkansas
(01-16-2022, 03:20 PM)BigJake Wrote: Here's my 4 cent's
The thing with ebay turbos alot of people get them install and go full send no priming no nothing. I put a $250 turbo on my old VW and tell this very day its going with no issues.
Kuch
Sep 2016
Manlius, NY USA
(01-16-2022, 03:31 PM)BigJake Wrote: Here's how I ran my breather hoses from the block and valve cover to the intake.
Jake,
I noticed you have a dipstick in the fender well, you have one of those dry sump oil reservoirs in there?
No dry sump, at one time I kept blowing the dipstick out so I just use a fuel hose with a bolt in the end wedged up under the vacuum tree. Every time I take it in for Inspection the guy can't find the tube to check the oil level LOL
