T-3 Turbo???
TurboBays Offline
Well I have a 87 TC and i was wanting to know if a T-3 turbo will fit in the stock location?? I have been looking for a SVO Turbo cause I plan on hooking it up to NOS when I chage turbo's. Do you recemend that i put a 3 inch down pipe on it when I change turbo's? Thanks for the help.
natmac3 Offline
Yes it will fit...
The 3"dp would be a nice addition, and will help lower the boost threshold.
Also, look into porting the E6, that too will help spool up.
Besides NOS, check out the other nitrous vendors, many of'em are making very nice kits. Shop around, never hurts...
1987tc
Lots of people have converted to T3s on 87-88 TC. a 3" DP is always a wecome improvement, but the whole exhaust system should be upgraded.
TurboBays Offline
Well I have already put on new flowmaster system.
TurboBays Offline
Where can I find T-3 turbos at???
Noname
Unregistered
Depends on how much money you want to spend. IF you're like me and don't wanna go all out. Find one on ebay that has been rebuilt recently or it in good enough condition that you can rebuild it yourself.
1988 TurboCoupe - 5 Speed - 115k miles - Fully Loaded except Leather
5"x8" K&N in fenderwell, SVO T3 watercooled .63/.60 A/R, Gillis Valve @ 18 psi, HKS Super Sequential BOV, Walbro 255 HP Fuel Pump, Kirban AFPR, Bob's Big Log Header, 3" DP, No Cat, Dual 2.5" UltraFlos into ATR SS axle/tailpipes, Centerforce Dual Friction Clutch, Pro 5.0 Shifter, Koni Adjustable Struts, KYB Gas-A-Just Rear Shocks and Quads, Custom Progressive Rate 1" Lowering Springs, M.M. C/C Plates, Energy Suspension Parts Everywhere, PST Ball Joints/Tie Rod Ends, Autometer Boost/Vac & Air/Fuel Gauges
If you are planning on using the stock IC, try to get a T3 with the SVO compressor housing, which is "plug and play" with the stock IC (no need to cut off flanges, reclock housing, etc).
TurboBays Offline
Where can I buy them other than ebay? What price do they normally run at?
Dan E Offline
Try the For Sale Section here and at www.turboford.org
Dan Eaves
Dan Eaves
