sway bar bracket bolts...
I want to change the bushings for my front sway bar on the 88 TC. I know the plastic nut holders usually break on these, but are the nuts and bolts just simple nuts and bolts and I can get rid of the plastic nut holder? Thanks
Did this years ago, sio my memory is a bit fuzzy..... I seem to remember just getting 4 nuts at the hardware store and reusing the original bolts which were in good condition. Those plastic things are just there to make assembly at the factory go faster.
