Suspension Question
turbobird63 Offline
I am upgrading all of my suspension but I am confused. CHE and Summit all state that the energy suspension components "will not fit Heavy Duty". Does The TC (mine is an 85) have the Heavy Duty suspension? What exactly constitutes a "Heavy Duty" supension?
I have searched but can seem to ind a definitive answer ???
Christopher Taylor
85 TC, 2.3l, LA3, T3/T4 Turbo 25psi, Stinger FMIC, Forge BOV, Full 3" Exhaust, Esslinger crank pulley- Timing Gears and overdrive WP pulley, BBK 255lph FP, Kirban AFPR, Kirban Shifter, K&N Cone, 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, Welded SFC's, and TON's of other parts.
turbobird63 Offline
Nobody Knows?
Ok how about If I put it this way ...Do I buy the Front Lower control arm bushings(Energy Suspension) with or without the sleeves?
Christopher Taylor
ipsd Offline
I bought the entire kit for my car saem part number as the mustang. It came with the metal shells on the front lower A arm bushings. So yes you want the sleeves.
