David85TC
Sep 2008
ReykjavÃk, Iceland
I'm going to buy Suspension bushing set, ball joint, etc.
Where is best to buy this?
I've been looking at the Summitracing and rock auto, there is a bit difference on the price, and diffirent brands, something that you would recommend?
Brand or where to buy.
Also where can I get Oil Pump Primer for our engine?
Thanks, David.
1985 Turbo coupe 71,000 miles Medium Red Metallic with Gray cloth interior, all option except leather and passenger power seat. All stock. But unfortunatly she has bad rust.
1988 Turbo coupe 88,000 miles Sandalwood with base leather seats, all option except moonroof and passenger power seat. Bone stock.
1985 30th Anniversary T-bird.
5.0TurboCoupe1988
Apr 2008
Broken Arrow, OK
the front lower control arm uses the same bushings as a '94-'04 mustang. i used the steeda offset bushings to help with caster. they are expensive but i think they're worth it.
http://www.latemodelrestoration.com/item...ngs-Offset
you can make an oil pump primer out of an old distributor. that's what i did.
1988 TC 2.3/5-Speed, 148K
David85TC
Sep 2008
ReykjavÃk, Iceland
Ok thanks for the advice.
Kev
Harrison Arkansas
Kev
At the time i just bought all replacements from ford, and mustang spring isolators because they were available. along with maximum motorsports front control arms.
-88 TC Black
-97 Pathfinder
David85TC
Sep 2008
ReykjavÃk, Iceland
Is the spring isolators not available now?
In what model of Mustang can i use the bushing from?
Because when i look for parts for the TC for example on summitracing there is not much selection, but it´s alot when i search for the mustang.
Is it just the fox body?
I need all the stuff front and rear and the Suspension End Links, Coil Spring Seats and ball joint.
Seem to me that i´m not finding any ball joint, and the coil spring seat, exept on rockauto, but i´m not sure about the quality and if it the currect part.
5.0TurboCoupe1988
Apr 2008
Broken Arrow, OK
as i posted above, '94-'04 mustang bushings...front and rear control arms. fox mustang ball joints and the isolator from either fox or sn95 mustang.
edit: i thought you were talking about an '87-'88 TC. looking at your sig, now i'm not sure. '83-'86 TC uses fox mustang bushings.
David85TC
Sep 2008
ReykjavÃk, Iceland
Yeah i saw that, i was not sure if you where only talking about the the front lower control arm uses the same bushings, because i need all the bushings front and rear and sway bar and the ends, just a complete kit, not only for the front lower control arm.
And also i was wonder if there were more model that would fit.
But this is the awnser what i was looking for, thx.
Yeah i was talking about the 87-88 TC, i thought the bushings where the same on the earlier TC, am i not right?
Do you think this would fit:
http://www.summitracing.com/parts/ENS-4-18112G/
Or this one:
http://www.summitracing.com/parts/ENS-4-18109R/
Bungy
Oct 2010
Minnesota
You might want to also check the front bushing in the rear lower control arms of your car. Some had round bushings and some had oval.
1986 TC 100% Stock
"Nitrous is for guys who can't build motors"
gtrag94
Jun 2004
Fort Wayne, IN
you apparently can rent an oil pump primer from AutoZone under their loan a tool program
1986 TC 5-spd (Red/Red cloth)
K&N Cone on VAM; front suspension by KYB, Moog, Energy Suspension.
