To put the PRC in diagnostic mode, locate the 2 pin connector under the ash tray, and jumper it. With the PRC switch in AUTO, start the car, and remove the jumper within 20 sec of starting. The FIRM light will flash out codes similar to the EEC code test. The PRC codes are 1 digit codes. Run the test, and get back to us with the results.
