Jeffrey Daly
Feb 2009
Wakefield, MA
Who makes good quality replacement struts and shocks for the 88 turbo coupe? Would they still be elec. controlled?
1988 Ford Thunderbird Turbo Coupe 5 speed/ Gillis Valve/ 140mph Ford Motorsport gauge/ RAM Powergrip Clutch/ K&N Cone filter
There are none that retain the PRC system. Monroe makes 1 or 2 models. Search on Monroe and you will find info
There is always the conversion to coil overs. Not cheap.
Like Pete said, PRC shocks / struts are not around anymore..... maybe a few sets left in the country.... maybe. If you found some, they would cost BIG $$. I have a complete set of 4 brand new PRC sitting in my shop. No, they are not for sale at ANY price.
87TurboBobby
Dec 2006
Colquitt,Georgia
Ah, come on Jeff I'll give you $25.00 a piece!
Bobby
lol
90 Mustang GT Vert.
95 Mustang Vert
04 F150 Heritage
92 Chevy Silverado
turbot79
Sep 2007
houstonTX
sn95 struts work fine and get chucks rear shock mounts but you have to get the mm cc plates for the front
88 tc, hbc, t3t4, 3"throttle body,3" stinger exhaust, msd, 18psi, Tial 50mm bov, Esslinger adjustable round tooth timing kit, rods header on the way and many more to come
Protowrxs
Nov 2007
Oklahoma
I recently purchased a pair of Monroe #5861's for the rear of mine - They are supposed to be a drop in from what the parts people could figure out. Will find out soon.
Too bad someone hasn't figured out how to use the PRC output to drive something larger and adjust manual adjustable shocks or something similar.
-Stephen
5861 for rear
71803 for front per monroe
o4 mach-1,white,4at 1 of 169 ,MAC air filter and x-pipe, SCT tune / o9 BMW 328 M-SPORT, white, 6at/ 87 Turbocoupe ,white,4at,KIRBAN afr,GILLIS boost valve,Garrett/SVO T3,cold air,3" STINGER down pipe and tail pipe, DYNOMAX ultra flow stainless muffler, Walbro 255L fuel pump,cleaned and flowed injectors,STINGER BOV, built A4LD trans w/all
4x4 Explorer guts, K245/F57FA torque converter.
