Struts
Ricky03 Offline
Ride control struts are shot. What is a good replacement strut and will struts for a SN95 fit? If not, what about fox mustangs
boosted chicken Offline
Everything I read says if your TC is stock ride height, SN95 struts will work and if your TC is lowered 1-1.5", a fox Mustang strut will work as it is bit shorter than the SN95 strut.
88 TC#1 Boport stg 3 alum dport head, PT6466, Boport header, CP pistons, Crower rods, MS2xtra
ianbfromct Offline
boosted chicken Wrote:Everything I read says if your TC is stock ride height, SN95 struts will work and if your TC is lowered 1-1.5", a fox Mustang strut will work as it is bit shorter than the SN95 strut.
Are the fox struts made to handle the weight differently? Im pretty sure the SN95s are a bit heavier than the foxes and wouldnt that adversely affect the handling if we ran fox struts?
Konis yellows,reds,KYBs,Billstiens..the world is your oyster..
Ive got Tokicos meant for a Fox and either these things are already beat or my Tbird is too heavy for them but it can be a bit bouncy. Im currently thinking about getting some new struts myself. Konis=big $$ but they are one of the best
88 5 speed TC
