DS_86Tc
May 2004
Cedar Rapids, Iowa
Is stop leak especially bad in these cars. Does it do anything to the turbo? (86 T3)
Dedpedal
Aug 2004
Ft Wright Ky USA
I had to work on a mid 80s cavalier that someone put stopleak in and it ruined the ect sensor and caused it to run hot and over heat all the time. If you do run some sort of stop leak, make sure its sensor safe!
87 Turbo Coupe
Ultimate weight reduction. A 93 Mustang coupe body.
tps87turbo
Feb 2003
Hammonton, NJ USA
What exactly is the problem? I would find the leak & fix it before putting that stuff in. They sell a dye you add to the system to detect an oil, freon, or coolant leak. One you identify it, then you should correct it .
Tony Sceia -
HIS - Red 88 TC, Med Red with Raven Leather & every option, Walbro 255, 3" SS Downpipe with Magnaflow Dual SS 2.5 Cat Back system, 3-core Radiator, Star Stage 3 Clutch, Rebuilt T-5 Tranny, 4:10 rear, 140 MPH Speedo, New Paint, Headlights, Refinished Snowflakes & New Tires.
HERS - Blue 87 TC, fully loaded with every option, Gilies Valve, K & N Filter, 3-core Radiator...just needs a little body work & a new paint job.
87 TC - Bought as a Parts Car, & will remain a parts car now that I found the blue one.
DS_86Tc
May 2004
Cedar Rapids, Iowa
Ive tried using it to stop up a leaking heater core to no avail. Looks like a heater core install is in store this winter along with the fifty other things the cars needs.
