dadsturbocoupe
Jan 2002
Camano Island, WA (USA)
I replaced the heater core, and now I get no sound out of the stereo. It turns on, lights up, runs the tape player(!), but no sound. Is there a plug/connecter to the speakers? I have began looking but can't tell if there is one. My fear is that when I pulled the dash aft to get to the heater, I pulled a wire from its connection. Any ideas?
Darryl
87 5-sp, black/red leather. Every option but sunroof.
91 Caprice wagon
66 Mustang convt w/5.0 AOD conversion, 4 wheel discs.
73 Mazda Rx2, 220 H.P ported 13B 74 Chev 1/2 ton p/u completely gone through (cause ya gotta have something to carry parts in!)
71 Datsun 510, race car/street car, father/son project.
2000 BMW 540iT. Beautiful car.
All living in my 40X72X12 shop. Sweet.
mjbtbrd
Dec 2002
Boston MA
there are 2 connectors on the back of the radio one may have popped off. also there is a wire with a round lug terminal on it that bolts to the stud on the radio back I would bet one of these 2 came off or the lug connected wire broke
thndr_chicken
May 2003
Memphis, TN
Also possible that the plug in the passenger side kick panel has been disconnected. The premium systems utilize a big separate harness that runs from the back of the radio area to the amplifier in the trunk. There is a big junction for the harness in the passenger kick panel. If it is unplugged the symtoms that you mention could exist because the radio would still have power, but the amplifere wouldn't. Hope this helps.
88 TC
Salvage yard long block doing fine
K&N in the fenderwell
5-lug conversion done / 17" Momo's on and looking good
Coil-overs up front, cut springs out back
Gillis valve
3" ATR downpipe / 3" single with Dynomax 3" Super Turbo muff
Fuel pump, adj. regulator coming soon
Boost and fuel pressure gauges are now in and functioning on the pillar
Did the heater core, what a pain!
Sequential flashers, thermostatically controlled forced air IC fan, and water injection all coming soon.
mh23turbo
Jun 2003
Frederick Md usa
MY 87 HAS TWO SPEAKER HARNESSES BEHIND THE HEAD ONE IS FOR NON AMPLFIED SYSTEMS THE OTHER IS FOR AMPLIFIED YOUR HEAD HAS NO POWER OUT SO TRY SWITCHING THOSE TWO PLUGS I BELIEVE THEY ARE GRAY BUT COULD BE BLACK CANT REMEMBER
thndr_chicken
May 2003
Memphis, TN
The black plug is the speaker plug. The one that goes to the input of the EQ and then to the amplifier has 3 wires on it. There is another with 8 wires on it tucked away in the dash. Those 8 wires go straight to the speakers and not to the amp. If you plugged that one in by mistake you would get low or now sound.
88 TC
5-lug / big brake M-2300 kit coming soon
Gillis valve
Want to build an Esslinger aluminum headed V8 eater
88 TC
Gillis valve
dadsturbocoupe
Jan 2002
The connections on the head unit itself are fine. I have pulled it out of the dash already and checked. I am leaning toward the passenger side kick panel, since I removed it to do the core. I get NO sound, so that makes the most sense. I see a flat, black connector that looks like it has 8 or so wires on it, but I have yet to see the other connection, so I'm not sure if I unplugged it or not. I will let you all know what I find out. THANK YOU!!!!!
91 Caprice wagon
dadsturbocoupe
Jan 2002
It was the gray rectangular connection in the passenger footwell. It must have come unplugged when I pulled the dash back, because I didn't do it purposely, and the black fabric behind kick panel wasn't removed or disturbed. I swear this site saves me so much time. I love it!
Thanks again!
Darryl
91 Caprice wagon
