Pat Fay
Jul 2001
Waterbury, CT, USA
I know this would be the cheap way and probally wont be any good, but I was wondering how would the STOCK 87-88 TC cam be if you retarded it a few degrees? Do you think it will be able to pull to the rev limiter 6200? I'm having second thoughs of spending 1000+ to do up my head. Plus I have the SVO itch again and want one. Who knows but do you think it will pull to 6200? Anyone do this? Thanks guys.
Pat - [email protected]
87 TC - 46k, K&N in fender, Gillis at 17-18psi, 3" downpipe no cat into 2 1/2" ATR Duals, 255 FP, AFPR, Chrome Cobra R's on 245/45/17's, Centerforce clutch
Sitting in garage - Air/Water IC, 65mm T-Body, ported E6, gutted upper
On its way - T3/T4, BOV, ported lower
Soon to come - Ported head w/ Oversized valves and .450 Rollar
Down the road - EEC Tuner, "big" injectors, 3.90 gears
I have heard of a few people doing it with either the stock or RR cams. Don't know how well it works, but probably not a lot with an IHI
DrPhang
Petersburg, Virginia,
Hey Pat... I was in your same boat check out http://natoubb.turboford.org/Forum1/HTML/006168.html
I am sure you can do even better than the RR, but I am VERY pleased with the diff it made!
Pat Fay
Jul 2001
Waterbury, CT, USA
See I have a few go fast parts sittin in my garage. I have a ported E6, Gutted upper, 65mm TB, and Air to Water IC. And after X-Mas (T3/T4, BOV and ported lower) the only thing I'd need to get is a Ported Big Valve head and good cam. But I was second guessing putting all that on a 3600lb TC and possibly run 13's when if I put the same stuff in an SVO I'd be able to see 12s. Plus if I got an SVO I woulnt have the problem of the car being my daily driver like the TC. Now I'm thinking of just installing the ported E6, Gutted upper/ported lower, and a T3. I asked the question about the stock internals because I know the stock cam stops pulling very early. I dont know what I wanna do just yet. Any opinions? I know this is a TC site but the weight and daily driver factor are way in favor of the SVO. What do you guys think?
[This message has been edited by Pat Fay (edited 12-25-2002).]
Pat, I'm not so sure it's the stock cam so much as the IHI that runs out of steam.
Pat Fay
Jul 2001
Waterbury, CT, USA
Maybe I'll put on a T3, ported intakes and E6 and thats it. Think a mid 14 is possible with that? Would probally go with the .48 housing because its geared more for the street.
Glenn 88TC
Lebanon, PA
I think it will have a chance at 13's if you drive it well. The stock cam will be fine to 6200. The ihi is the limiting factor now. That is very similar to Stevex82's combo.
Glenn 88TC
current mods: ported & polished big valve head(1.89/1.59), ranger roller, custom upper and ported lower intakes, t3/t4 turbo, powerstroke intercooler mounted full size, 60mm throttle body, R.C. Engineering 42lb. injectors, MSD 6al, MSD Launch Control, MSD 8.5mm wires, K&N filter, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, full 3" exhaust with Dynomax Ultraflow muffler, Star stage III clutch, Hallman boost controller, Flex-a-lite adj. temp switch for stock fans, Weld Draglites with M/T ET Street 26x11.5/15
[This message has been edited by Glenn 88TC (edited 12-26-2002).]
NO TC and NO headaches.
