Puchrider
Feb 2016
Georgia USA
Hey, wanting to replace a worn-out muffler with a straight-thru Dynomax Ultra-flo. From what I gather, many are opting for the 2.5" diameter offset/offset 17222 model. Would this fit into the stock setup? Just want to make sure 2.5" would work due to the fact that my measurement was closer to 2.25". Maybe I didn't get a good read? In other words, what is the stock exhaust diameter? Did a search for "stock Turbo-Coupe exhaust diameter," but had no luck for some reason. Car is a 1986 model. Thanks!
~Puchrider~
1985 BMW 325e
1986 Turbo-Coupe- 3rd Owner
1995 BMW 325is- Daily
1998 "Banana-Yellow" Mark VIII LSC-CE- TR3650 Swap Pending..
2007 "Banana-Yellow" Peterbilt 386- Converting into an RV
It will be much better in the long run to either replace, as in "upgrade", the entire exhaust system when you can and if that is not feasible now, then patch what you have as cheap as possible and start planning for the upgrade. Improving the whole exhaust system, manifold to tail pipe tips is probably the one biggest thing you can do to improve performance now and get the most out of any other mods down the road. http://turbotbird.com/techinfo/Mods/Mods01.htm
The stock system is more like 2.25" at the mufflers and tapers down to 1 & 7/8" after the mufflers
^^^^ +1
The stock exhaust system is pathetic. As Pete said, patch it for now until you can afford a complete turbo to rear of the car large diameter system. Check out Stinger Performance for good systems at a reasonable price.
BirdJunkie
Aug 2007
Erie,Pa...Go Otters!!
Stinger ROCKS....Just bought his complete system for my 88 and it made a noticeable difference. I went 3" from the turbo with dual 2.5" mufflers and tails. His is all mandrel bent and is the real deal.
88 TC 5SPD BLACK MY BABY ORIG.OWNER(garage queen)/06 GTO 6SPD RED WIFES CAR(cop magnet...lol)/2011 TAHOE WHITE (wifes daily driver a.k.a Fifty Cent)/2016 SUPER DUTY RED(my daily driver a.k.a BIG red)/06 HAYABUSA (SEXY BITCH)..STATEFARM LUVS ME. ----N.A.T.O Bad Boy Division President----
Puchrider
Feb 2016
Georgia USA
I appreciate the responses, thanks guys! Even though there are obvious performance gains with an entire system upgrade, I am wanting to keep the car as original as possible. The muffler has been patched already, just wanting a suitable replacement. It sounds as if the 2.25" 17226 model will fit?
~Puchrider~
1985 BMW 325e
Puchrider
Feb 2016
Georgia USA
05-25-2016, 03:49 PM
(This post was last modified: 05-25-2016, 03:50 PM by Puchrider.)
Duplicate Post Removal
~Puchrider~
1985 BMW 325e
turbo80sdriver
Nov 2008
Erie, pa
I will attest that Birdjunkie's Stinger system sounds about as good as one could imagine any (otherwise stock for now) 4 cylinder engine could sound! So good, I'm getting one of my birds the same treatment by the same installer in the near future!
On my Bluebird, the first generation exhaust replacement (in aboot 1994) was a custom stainless system behind the cat with straight throughs - sadly, of stock diameter (Dad wasn't into Horsepower upgrades for his daily driver, he just wanted to never have to replace the system again, and so far it's been 22 years running!).
There's a few TC's out there that just sound so optimal, but all are upgraded diameter systems - let it flow, man! You'll smile when you put the beach towels in the trunk while it's running! and then the smile will widen as the throttle eases you a bit further back in your seat!
'88 TC-Black T-5 with 79K stock 98.5% original, just w-i-d-e rims and tires, and some under hood powder-coating
'88 TC-Blue w/98K. Stocker w/t-5 ( the resurrection car) top gas mileage =31 mpg!
'88 TC-Grey w/99k. Auto, well optioned, 2nd owner car - getting more options
'87 TC-Blue w/123k t-5 parts car - less of a car now
'88 TC gray- body only so far- very very late factory build dated car, awaiting resurrection
'87 GN w/16.8K
"96 Bronco XLT w/351 (5.8l)
Puchrider
Feb 2016
Georgia USA
Dynomax Ultra-Flo 17222 installed on 6.3.16; sounds great! Car is actually quieter now because it had an exhaust leak. It has a deeper tone and sounds smoother. Will post a video when the weather is nicer. I kept the rest of the system stock.
~Puchrider~
1985 BMW 325e
margood
Apr 2014
Casa Grande, Arizona
I'm going to be installing a 3" downpipe with no cat and a single muffler exiting to the passenger side. The Dynomax is my first choice when I do mine.
87 TC Not bone stock anymore, no rust, sittin' pretty, always trying to get it running...
ABird
Mar 2011
Myerstown, PA
Hi All,
I recently purchased an 88 TC. It has no exhaust system, It only had the stock catalytic converter. I see recommendations above to remove the stock stuff. What is the stock setup, dual exhaust, with 2 mufflers? Thanks in advance.
AES
